The Bangs prop is a good idea. Just take a piece of a sphere and map it, you can yes a picture of real bangs as a guide. For the hair behing the ears, just do the same thing, except use a square or triangle. Put 2 or three on each side. It doesn't need a lit of hair and that little bit will really make the model work.
If you look at Phil's Romantix for Vicky, 2 or 3 of the hats have bits of hair to go with them. It really does help avoid the bald-headed look, and you don't need much. If you tuck a couple of bits behind the ears, do it so that they don't disappear when the camera angle changes, and so that they still look right when she turns her head to each side. Carolly
