Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Don't know if this helps or not, but I had a similar rendering problem with the hi-res Mike figure. The problem turned out to be Windows ME. Basicly, it's a hunk of junk. I upped to XP and everything has been fine, I've been able to render multiple high res figures in the same scene. So, if you're running ME... ditch it for Win 2000 or XP. Jack
Thanks lemur01. Im using XP. I have been able to render at higher resolutions. Sometimes I can and sometimes I cant. It may be because of other apps Im running. It's really irritating that you cant trust poser render the way you want to. Again thanks. Petur
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Yes&Artist=Vestmann
Does anyone know a good trick to help poser render at high resolutions? When I'm using StephyZZ's Yuma texture I can't render at more then 800x800 and that's without hair and props. I have a 600 Mhz, 512 MB PC, I also have GeForce 3 card but I understand that doesnt do any good in poser. I know that disk space helps poser, I have about 5 Gigz free but I was hoping that were some other solutions for the problem. Any ideas?Vestmann's Gallery
