Sun, Feb 9, 1:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Subject: Animation Help
DCsharker ( ) posted Tue, 23 July 2002 at 2:57 AM ยท edited Tue, 04 February 2025 at 6:05 AM
ok ok i made a Horse and a guy the horse is running and a guy is on the horse, he falls off holds onto the tail then holds on with one hand then flies off skids on the ground and then his head goes in the ground. While he is dragging he starts to slow and then his upper body goes under ground, now what I nead is some like dirt i can make, like i need to make it so while he is dragging Dirt is flying up from were his body is dragging. and then when his head goes under you cant see it due to dirt, can someone help?
saxon ( ) posted Tue, 23 July 2002 at 9:57 AM
Blimey! There is an excellent Python script based particle system for Poser Pro Pack on sale at Daz, it's called MK particles (I think) but certainly part of MK scripts. I've used it for leaves blowing in the wind and a few other things so technically it's possible but..... not going to be easy...
DCsharker ( ) posted Tue, 23 July 2002 at 1:44 PM
Thanks. (you said its not going to be easy) well i am no newbie, thanks though i will check it out.
