I remember readind the 1st DA article about Poser animation in Bryce. It was about an weird method using spheres as joints to animate the model. Perhaps she improved the method, but I have some doubts about that. Animating in Poser with all the dials and curves is a hard task, imagine trying to do the same rotating/translating spheres with Bryce controls. What happens with the mesh at the seams? I've just DL the br4 file to give it a try. Thanks for the info Hawkfyr.
As far as I know You have to import the avi(not quick time)into poser from the file menu file/import/avi footage. then load the avi done in Poser using file/import/poser document and render. I've never done this but I have added music to a Bryce animation by importing it into Poser and then adding music and re- rendering it in Poser and that worked fine. hope this helped Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Attached Link: Bryce charecter animation
I just got this link from thr alt.binaries 3D bryce newsgroup.I'm d/loading it but hav'nt used it yet, just thought some of you might wanna check it out.“The fact that no one understands you…Doesn’t make you an artist.”
