Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Well one of the problems I've found is that the tailor doesn't do a recursive search for associated Pbms from the FBM. Take Pear figure for instance, it will effect HipSmall however only in the hip and that's the only place it will attempt to make that morph. However if you look at the info for Hipsmall it also effects 5 other pbm locations (abdomen, lbutt, rbutt, and the thighs) and these aren't selected or linked in the new Pear FBM. So you would have to add the Hipsmall morph FBM and effect it to creat PearFigure. If you need to see where I'm going in 1.1 just right click on the FBMs and look at the more info. It'll be pretty evident after that. Just a limitation, and one that could be fixed I'm sure with a lot of parsing and txt searches. Tom
Just some follow up info in case I went over the respective heads. But when you click on the PearFigure (Which should effect all the Hipsmall morphs as well) it doesn't grab all the effected PBMs. Tom Full Body Morph:PearFigure (PearFigure) 16 morphs linked Morph Actor deltaAddDelta BreastSize4 chest 0.60 BrstNatural chest 0.25 LatsSmall chest 1.00 TummyOut abdomen 1.00 AbsSoften abdomen 0.70 CalfFull rShin 1.00 KneeBulgeFix rShin 1.00 ThighWide rThigh 1.00 ThighFull rThigh 1.00 HipSmall hip 0.20 GluteDimple rButtock 0.40 CalfFull lShin 1.00 KneeBulgeFix lShin 1.00 GluteDimple lButtock 0.40 ThighWide lThigh 1.00 ThighFull lThigh 1.00 Full Body Morph:HipSmall (HipSmall) 6 morphs linked Morph Actor deltaAddDelta pbmHipSmall abdomen 1.00 pbmHipSmall rThigh 1.00 HipSmall hip 0.75 pbmHipSmall rButtock 1.00 pbmHipSmall lButtock 1.00 pbmHipSmall lThigh 1.00
i'm getting a lot of problems with the tailor, i hope it's me but many clothes do not apply correctly with it, my main concern is with billy lingerie set, on ly some of the body parts ger morphs? do you have the same problem?? thanks
