Mon, Jan 27, 3:30 AM CST
Subject: Bryce Forum no Help! Pose to Bryce question!
zorares ( ) posted Thu, 25 July 2002 at 3:08 PM ยท edited Mon, 27 January 2025 at 3:23 AM
Sorry to bother everyone here but this problem has almost got me committed! After I import my figure into Bryce 5 (stephanie in this example), her eyelashes and eyebrows are horrible and I can't figure out how to get the transparencies applied properly. Please, don't have me sent back to the funny farm! : ) How do I fix this?
http://schuetzenpowder.com/sigs.jpg
wdupre ( ) posted Thu, 25 July 2002 at 4:05 PM
what texture are you using becouse if it uses the no brow morph and a surface texture you should deleate the upper and regular eyebrows. if not group them with the eyelashes. in the materials window what I do is click in the circle next to transparency, in the image texture load black in the first window and the steph trans map in the second window. then in the drop down menu click on blend transparency then set diffusion and transparency to 100 everything else to 0 and use the diffusion color dot to set the lash and brow color
LadyTieryn ( ) posted Thu, 25 July 2002 at 6:36 PM
Attached Link: http://www.awakemm.com/poserarcana/tutorials/tb/tb01/04.html
Here's a link to help with any other problems you might have with importing them into bryce. It was very helpfull to me. :)
brycetech ( ) posted Thu, 25 July 2002 at 10:10 PM
select the part you wish to apply the transparency to select the "M" for material 1. put a dot in the transparency channel 2. click the picture texture button 3. enter the picture lab 4. load an image into the first window (this is optional and is used for color..it does not have anything to do with the transparency) 5. load a grayscale image into the second window (this is the image that will drive the transparency) 6. back in the material lab, select "blend transparency" so that objects are totally transparent do interact with light. see image luck BT
derjimi ( ) posted Fri, 26 July 2002 at 7:53 AM
Quoate: "Bryce Forum no Help!" Zorares, come over to my house and I teach you to use the "Search"-Function of the forum. There are a bunch of topics giving tips about importing Poser into Bryce. Just open your eyes before you complain.
