Fantastic!
Hmmmm. I got an error when I tried to look at the horse DB. It said "blahblahblah horse table not found". But after I looked at the male DB table. The horse one worked. Maybe the male DB needs to be launched first because of the way the code is written? Sorry. Couldn't remember the exact error message. ScottA
Attached Link: PhiFactory V1.2
![file_122902.JPG](https://live.cdn.renderosity.com/forum/_legacy/file_122902.JPG)
Well PhiFactory skipped right from 1.0 to 1.2 but there have been some interesting developments. * Integrated Body Part and Rotations Data Base Tables - Using these tables, you can copy the standard P4 Body part names and joint rotations to the edit line. Add a heirarchy number, use 'Add Line' of 'Add Child' and the entry is entered into the new .phi file. No more spelling errors or hunting to find the right joint rotations for that standard part. You can mix and match parts from several tables including the P4Human (P4NM as the base), P4Cat, P4Dog, P4Horse, P4AngelFish, P4Horse and P4Dolphin. (I've been tinkering with this part to pre-plan models. Sort of a top-down approach to get an idea of how the joints would work if I stuck a P4Dolphin, P4Human, and P4Raptor together ;-) ) * Joint Rotations Quick Reference - Need a reminder of what the rotations should be for that body part? The Joint QRef panels display an image of a P4 Biped (human) or P4 Quadruped (horse) with the joint rotations noted. * Enhanced user interface - By moving some of the functions to a menu bar system, the user interface is cleaner and easier to use. Only the buttons that are used most often are next to the edit window. * Integrated Help - A new integrated help system gives details on all the buttons and menu items. You can get it at http://bushi3d.com More to come. The next point of departure is getting PhiFactory to understand .pz2 and multi-figure .cr2 files.
