Fri, Dec 27, 12:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Please test a prop...
Geekholder ( ) posted Sun, 05 March 2000 at 12:41 AM ยท edited Thu, 14 November 2024 at 12:21 PM
Attached Link: A Dungeon Portcullis
I've never posted a Poser prop (pp2 file) to the FreeStuff before, and I'd like someone on a PC to test it first. It was created on a Macintosh. I used Martin Christgau's Macconverter to export a PC rsr file, but left the resource fork in the pp2 which the Mac Poser uses. Could someone on a PC please place the pp2 and rsr files in the libraries folder and check the following: 1. Does the preview thumbnail appear, or a shrugging poser guy? 2. Does the prop load properly into the Poser window? 3. Does it find its texture? 4. Do the morph dials work (6 morphs to bend the bars)?
shdwcstr ( ) posted Sun, 05 March 2000 at 2:03 AM
Just dropped it out of the zip and into my props folder. The pic showed up fine and everything works great. Thumbnail appears Prop loads properly Texture was found and used automatically All 6 morph dials work FYI: I didn't use the dir structure from the zip file either, dropped pp2 & rsr into a prop folder (scenery) and dropped rust into textures/metals. I did absolutely nothing to any of the files and they still worked like a charm. Whatever you did, you did it right.
Geekholder ( ) posted Sun, 05 March 2000 at 2:50 AM
Thank you very much. I've uploaded it to FreeStuff.
