Fri, Nov 22, 11:46 PM CST
Subject: I am Scr2ed
Replicant ( ) posted Sat, 03 August 2002 at 10:41 AM · edited Fri, 22 November 2024 at 8:48 PM
Is there a utility or technique that will allow me to extract cr2 files from pz3 files? I am sure I've seen it mentioned somewhere.
Expert in computer code including, but not limited to, BTW; IIRC; IMHO; LMAO; BRB; OIC; ROFL; TTYL. Black belt in Google-fu.
TrekkieGrrrl ( ) posted Sat, 03 August 2002 at 10:57 AM
you could open the PZ3 and then save the characters to your Character library. This will create a cr2
Barbarellany ( ) posted Sat, 03 August 2002 at 11:39 AM
You will have to delete the extras , ie props, if you want to save just the character then revert delete the main character and save props one by one. you can make a new library folder then hit the plus (+) to add them. Props should go to props library.
Stormrage ( ) posted Sat, 03 August 2002 at 11:51 AM
just rename the pz3 extension to a cr2 and put in your Figures Library. There is also a pz3 to cr2 converter in freestuff. (this is if you want the WHOLE thing in the library, lights screen settings et all)
Replicant ( ) posted Sat, 03 August 2002 at 1:26 PM
Many thanks for the replies. Thats what I needed to know. :o)
