Fri, Feb 7, 1:42 PM CST
Forum Moderators: Staff
Subject: a qustion about 3dsmax
oldcat ( ) posted Wed, 07 August 2002 at 1:31 AM · edited Fri, 31 January 2025 at 2:14 PM
I export a figure as wavefront .OBJ file from poser, but when i import the .OBJ file into 3dsmax, I can not see the figure from the viewport of perspective and camara. what's wrong?
bushi ( ) posted Wed, 07 August 2002 at 1:43 AM
The Poser .obj meshes are very small relative to 3DMax. Use that align to view to zoom to the mesh. If it's something you're using to alter for an MT it's best to leave it at it's imported size, if not you can scale it up, work on it then re-scale it back to it's original size.
oldcat ( ) posted Wed, 07 August 2002 at 1:59 AM
Ok! Thanks a lot bushi
maclean ( ) posted Wed, 07 August 2002 at 2:41 PM
Attached Link: http://www.renderosity.com/~syyd/tuts/impexmax/impexmax.htm
Try the link for correct import sizes in obj from poser to max mac
oldcat ( ) posted Wed, 07 August 2002 at 9:57 PM
thank you for your help Maclean!
