Mon, Jan 27, 7:33 AM CST
Subject: Props does not render
Holli ( ) posted Wed, 07 August 2002 at 3:23 AM ยท edited Sun, 26 January 2025 at 4:26 PM
Attached Link: http://www.atomic-knights.de
Yesterday something real strange happend. I was working on a scene for some days with some own props I created. I added them to the props libary. After I loaded the scene the following day all of my props did not apear on the render. I have no idea why. I deleted the props from the scene and applied them again from the libary. Everything was back to normal. Did this happen to anyone before ???
PhilC ( ) posted Wed, 07 August 2002 at 4:27 AM
Yes I've had this happen to me and I did what you did to get round it. No idea why it occurs though.
Don ( ) posted Wed, 07 August 2002 at 10:10 AM
According to Greg Crowfoot... I've run into this problem before when making characters. It is a peculairity of Poser and seems to be a memory issue. MY solution has always been to delete the item in question and then re-introduce it into the scene. That usually works. Failing that, another solution has always been to exit Poser, restart the system and then come back into Poser and try again (re-introducing the prop if required). It seems that Poser 4 will sometimes try and do a 'shorthand' version of a scene when memory, or system resouces starts running low from multiple renders.
Allen9 ( ) posted Wed, 07 August 2002 at 1:28 PM
Same thing happened to me with assorted jewelry on a character. One render was OK, the next day I opened the scene and none of the jewelry would render. I deleted it all and re-introduced the props, and then it worked. Freaked me out at the time. Interesting to know I'm not the only one poser has done this to.
Holli ( ) posted Thu, 08 August 2002 at 12:06 AM
Thanks for all you comments. I'm not sure this is a memory issue. Because I happend right after I started my computer and Poser was the only application running. Even exit and restart did not help
