Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Hi Djuke. Speaking personally I render large to print them off. I would only reduce the size to post onto a gallery, just for bandwidths sake. Rendering large and scaling down helps with things like sharpening the picture. It is easier to add detail to a larger picture and some of that detail still remains when you reduce it. Your example of 3000x3000 reduced to 800x600 is a bit excessive though, most examples above only reduce a small amount. As an example try reducing a digital photo, you will be suprised just how small it can go and still be identifiable.
at least 2800x2800, 100DPI. I do a lot of postwork, and it's a hell of a lot easier to work huge and shrink than it is to work small. Then I shrink to 72 DPI (for screen resolution), sharpen, then shrink to gallery posting size. But I save a copy of my original piece, in case I ever get around to making a portfolio of my work.
For those who aren't aware, an ideal ratio for a "landscape" rectangular orientation is 4:3, the ratio of most computer monitors (no matter what their resolution or size.) IOW monitors displaying at 1024x786 and those displaying at 800x600 both have the same ratio. This might sound very basic or tangental, but it helps to become familiar with how the 4:3 ratio translates at different sizes when planning your test renders vs. final pictures. Shrinking an image's size isn't the same thing as anti-aliasing, it just has a similar perceptual effect. I used to overdo it: I'd render at 3Kx3K when the finished product was 800x600. At that large of a difference, much of the postwork I did was unnecessary (e.g. guassian blur on edges.) Obviously those working in high-quality print and TV media will want larger resolutions, but for computer-only use it seems like rendering at merely two times the size you intend the finished product to be is fine.
HI Im interested in the size people render in with poser. Im aware that PAL DV is 720x576 which looks ok on TV. What are the preferences of the Poser community here? Cheers -LW
