Tue, Jan 7, 4:30 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: making ghosts in carrara with poser
Ghost ( ) posted Wed, 08 March 2000 at 11:38 PM · edited Tue, 31 December 2024 at 10:24 AM
how would i get a "ghost" like effect going in carrara with a poser 4 figure????
MarkBremmer ( ) posted Wed, 08 March 2000 at 11:47 PM
I suppose the easiest would be to import the Poser OBJ file with no texture map, then make sure 'None' was selected on the color option in the shader multi channel tray, play with the value slider in the trancparency channel, and finally add a 'blur' value of 4 to 10 in the object filter tray. Mark
Ghost ( ) posted Thu, 09 March 2000 at 12:05 AM
but i can still see the back half of the character. is there a way to avoid this??
MarkBremmer ( ) posted Thu, 09 March 2000 at 12:20 AM
Eliminate the transparency, designate the color white and keep the blur. With the loss of transparency you'll probably want to use the value slider (or assign white as the glow color) in the glow channel and play the Aura control in the scene settings filter tray. Mark
Stacey ( ) posted Thu, 09 March 2000 at 12:33 AM
you could also try and put some smoke in front of the figure it ay help but it may also grey out the figure to much .......
