Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 12:13 pm)
Bottom-right? I hadn't heard of that one. Try this: Get your interface just the way you like it then memorize it with a UI Memory Dot. We you re-launch Poser and it's messed up, press that memory dot. It should put everything back for you. It works for me when my doc window gets stuck in the upper left.
Ok I recently had a bad hard drive crash and after installing poser 4 and the patch I can't sem to get my interface to stay the way I want it. I set preferred state and tell it to also use the previous interface but all that happens is that my window size remains teh same but trails off the screen to the bottom right and all the tool interfaces revert to the factory states. What am I doing wrong as I can't remember this happening before.
