Thu, Jan 16, 6:50 AM CST
Subject: Uhm i feel like rally really stupid but....
RiffUlven ( ) posted Tue, 13 August 2002 at 9:15 AM ยท edited Thu, 16 January 2025 at 4:52 AM
How do ichange the size of the vue D'esprit image im making cause when im uploading ill get a message that sez it can only be between 100 and 4000 how do i change it between 100 and 4000?
gebe ( ) posted Tue, 13 August 2002 at 9:26 AM
100 and 4000 what? Kilobytes? Pixels? Normally you change a picture size in a paint program. But you also can render directly in Vue in the right size. Give some more details please.
RiffUlven ( ) posted Tue, 13 August 2002 at 9:40 AM
Form validation error The image height must be between 100 and 4000 pixels wide. Please press Back, correct the errors, and try again. how do i change the pic between 100 and 4000 pixels in vue D'Esprit?
gebe ( ) posted Tue, 13 August 2002 at 9:49 AM
I suppose you use Vue 4? Then you find every thing about it in the User Guide page 100. Just input your render size as the image (page 100!) shows and render. What was your original image size? Bigger then 4000 pixels? Tht's nearly incredible. Smaller then 100 pixels? Incredible also. Do you have a paint program? Open your image in that program and see the size in pixels and KB. If you have more problems, just write again.
RiffUlven ( ) posted Tue, 13 August 2002 at 9:52 AM
I use Vue 3.02
gebe ( ) posted Tue, 13 August 2002 at 9:54 AM
In the Vue 3 User Guide page 75!
YL ( ) posted Thu, 15 August 2002 at 7:15 PM
Other possibility : right click on the render button, then you will see a new window with a zone where you can change the render size (ratio length/height; and number of pixels) Hope it helps ! Yves
