Tue, Jan 21, 4:00 AM CST
Subject: Poser 4 to Bryce 3 works fine
Ghostofmacbeth ( ) posted Fri, 10 March 2000 at 2:21 PM · edited Tue, 21 January 2025 at 12:19 AM
Here is something I did real quick and it works no problem .. If you need anymore help please let me know. Import figure into bryce. It will come in grey. Apply a basic material like the glossy wood texture. This will apply highlights for a sweaty person so you dont have to do it manually. Click on the little P on the material, this should show the leonardo picture. Click the second button on the top and the load in the picture. If you hit okay the texture will be all wacky at first. You have to click on the top left button whch is the editing control ... rotate the texture 180 degrees. It should then be all set ... Good luck I might be a little off on which button is which but they should be easy enough to find .. good luck
Rita ( ) posted Fri, 10 March 2000 at 2:55 PM
I did that already and it still didn't work. Did find out though textures work on Poser3 models.
