Thu, Jan 30, 8:20 PM CST
Forum Moderators: Staff
Subject: in what way I can change camera and to see the change of camera in the preview.
max20000 ( ) posted Fri, 16 August 2002 at 12:40 PM · edited Fri, 17 January 2025 at 9:18 PM
in what way I can change the select camera (left, aux, face ect.)and to see the change of select camera in the preview and in the final movie.
Ericroy ( ) posted Fri, 16 August 2002 at 3:15 PM
You can not change cameras during an animation. You can move the camera you start with, but you can't change to another camera. I hope this helps, Ericroy
max20000 ( ) posted Fri, 16 August 2002 at 6:13 PM
very thanks. then I cannot use other cameras in the same video. it's possible to combine varied videos (with other cameras/angle) in post production only. You know if in Bryce 5 I find this same problem?
doozy ( ) posted Sat, 17 August 2002 at 8:03 AM
Post production, yes. Of course you should render only a short segment at a time, then combine them all in post. So using another camera (or switching to another scene an any other way) is a natural spot to stop one PZ3 and start the next.
