Sat, Jan 11, 7:13 AM CST
Subject: Dr. Who's Scarf now ready to wear...
geralday ( ) posted Sat, 17 August 2002 at 6:06 AM · edited Sat, 11 January 2025 at 7:12 AM
Attached Link: http://205.122.23.229/geralday/index.htm
***Hope it does the job !******![gerald.gif](http://205.122.23.229/geralday/gerald.gif)***
Khai-J-Bach ( ) posted Sat, 17 August 2002 at 6:34 AM
thanks Gerald :) I should have an addon for our good Doctor later on.. keep you all posted ;)
chohole ( ) posted Sat, 17 August 2002 at 7:18 AM
Thankyou very much.
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
Khai-J-Bach ( ) posted Sat, 17 August 2002 at 7:53 AM
Attached Link: http://www.imdanet.com/~kai/modelrelease/sonicscrewdriver.zip
here we go.. the Sonic Screwdriver! I've done the modeling...but my Poser texturing skills are not upto much and as for smartpropping it... gaaaaahhhh!! I'm a truespacer ;) so here's the basic OBJ, in the hope that someone will do the textures ;)
melanie ( ) posted Sat, 17 August 2002 at 10:12 AM
To make a smart prop, all you have to do is bring the prop into Poser, position it the way you want it, parent it to the hand or whatever body part you want it to smart prop to, then save to the Props library. It will ask you if you want to make it a smart prop. Click Yes and it will automatically save as a smart prop. You don't need to mess with a document editor. Poser will do the work for you. As for texturing, UVMapper will do the trick. Hope that helps some. And Gerald, thanks for the scarf. It's perfect! Kaibach, thanks for the sonic screwdriver. Another great addition to the Whoniverse! Melanie
JHoagland ( ) posted Sat, 17 August 2002 at 6:51 PM
Gerald- Your picture is all wrong! K-9 would never say, "Beep!". He should be saying something like, "Master, please don't on me. I was not constructed to support the weight of a person." And since the Doctor is sitting on K-9's top control panel, shouldn't K-9 be spinning around or firing his blaster or something? --John
VanishingPoint... Advanced 3D Modeling Solutions
melanie ( ) posted Sat, 17 August 2002 at 9:02 PM
Affirmative, Master! Melanie
