Wed, Dec 25, 9:03 PM CST
Subject: A more basic Poser texture problem
Tiswas ( ) posted Sat, 17 August 2002 at 8:35 AM ยท edited Wed, 25 December 2024 at 8:55 PM
I cannot seen to import any textures from Poser in to Vue4. Ok, I know I'm only using Poser 3 so I can't use the pz3 format. However Vue4 reckons it can import 3DS & OBJ objects with full texture conversion. I have exported from Poser in both these formats but no textures are there when I import into Vue 4. Can anyone help out? Cheers Mark
gebe ( ) posted Sat, 17 August 2002 at 8:57 AM
As I have Poser 4, I cannot try with Poser3:-)But maybe I can help you anyway.
When you export your Poser 3 Figure, you must first separate the HAIR from the Rest of the body. I want to say the hair must not have a parent. That's very important.
Then you may try the following: Before you import your Poser figure into Vue, create a folder where you put all the maps of your Poser figure and also your Poser OBJ.
I imagine now you have exported from Poser the casual woman in OBJ format. She has a Poser 3 which you have "configurate Parent=NONE".
Then fire up Vue and import your OBJ from the newly created folder. You will now see a file called "Casual Woman" with a cross in front of it. When you open it in clicking on the cross, you should see at least "Figure" and "Figure Hair". If you have exported from Poser with all the components of the figure named separately, you will see insteed of figure and figure hair a long list of all the components.
1.)If: You only see Figure and Figure hair:
select Figure, then double-click in the material window to open the material editor. Choose MAPPED PICTURE and then click LOAD. Load the file called "casual woman", click OK. The mapping should come out well now. Then click Figure Hair and double-click again in the Material Window, choose Mapped Picture-->Load and load your Hairfile.
Render.
2.) If: You have exported your Poser figure with detailed components, you have to do this for everey component and the hair separate. To make this faster, choose the first element (except the hair), load the material for casual woman. Then copy this material and past it to all the other components. At least map the hair.
This should work. And make sure you have the latest upgraded version of Vue, what's Vue 4.1.
Let us know if it goes as you want:-)
Guitta
gebe ( ) posted Sat, 17 August 2002 at 8:59 AM
I wanted to insist to export your figure in OBJ format.
Tiswas ( ) posted Sat, 17 August 2002 at 9:10 AM
Thanks gebe, for your very detailed reply. I haven't had chance to try this yet - but I certainly will and I'll get back to you either way. Thanks again. Mark
notefinger ( ) posted Mon, 19 August 2002 at 2:23 AM
I just bought a house from Ironworks. It looks very good in Poser4 but only half good in Vue4. The roof looks like a Smurf roof with out textures but the color is Ok. The bricks look like the right color but smeary texture. I saved the file as a Poser file and imported it as such but it looks sucky.
notefinger ( ) posted Mon, 19 August 2002 at 2:42 AM
So any way I took the object files and the texture files of the cottage from the Poser runtime folder and put them together in another folder named Cottage. I imported the obj file into Vue and it was able to find all the textures. The house looked perfect ust like the picture. It seems like saving in pz3 formate still needs some work. Any way this technique leaves of the middle man Poser.
Tiswas ( ) posted Tue, 20 August 2002 at 5:36 PM
Hi Guitta I said I'd get back to you on this. I'm still getting texture mapping problems in Vue using the technique you described. I've taken to cutting up Poser texture maps into the individual areas & mapping in Vue to all of the different body parts. I still need more practice with this but it seems to get ok results so far. Although I suppose I'm really gonna have to save up & get Poser 4 (or 5 now!) Thanks for you help
