Tue, Feb 18, 5:17 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: ProPack Flash settings: "You may only enter numbers here"
wotsupdoc ( ) posted Sun, 18 August 2002 at 2:53 AM · edited Thu, 06 February 2025 at 5:20 AM
I tried to make a flash animation in Poser ProPack Version 4.20 build 160. I noticed the following bugs: 1) When I enter the animation/make movie/flash settings and change nothing, press "ok" it generates the following error msg "You may only enter numbers here". Changing parameters doesn't help 2) The flash export thingie will not obey the resolution (size) setting QUESTIONS: A) has anyone found a solution or workaround for the amount of colours (4 colours suck) B) does anyone have a version of ProPack that will work with the flash settings?
wotsupdoc ( ) posted Sun, 18 August 2002 at 8:23 AM
OK, I found the answer in this forum. Over a year ago someone has found a solution to this problem. My Poser version is English (this uses a decimal dot) My Windows version is Dutch (this uses a decimal comma) Poser interprets the comma (,) as a letter and generates the error msg Thanks everyone!
