Thu, Feb 6, 12:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 11:58 am)
Subject: A question about michael 2.0, and a problem with poser 4
bubbrock316 ( ) posted Mon, 19 August 2002 at 9:37 PM ยท edited Thu, 06 February 2025 at 12:00 PM
First I want to ask, how do I get rid of those ugly eye brows? And somehow, my poser window where the figure appears got shoved all the way up in the corner, how can I get it back down in it's default position?
wdupre ( ) posted Mon, 19 August 2002 at 10:55 PM
Ugly eye brows? which texture are you using? as for the layout just go to edit/prefrences/use factory state.
bubbrock316 ( ) posted Mon, 19 August 2002 at 11:12 PM
The eyebrows that seem to be default with the character. They are much like the p4 male ones. Thanks for the soultion to the window problem, it worked great.
Little_Dragon ( ) posted Mon, 19 August 2002 at 11:20 PM
Quick fix:
You should find a BrowsGone morph on the head; when used, it hides the upper eyebrow layer inside the skull. Or set the material's transparency values to maximum, so you can't see it when rendered.
Not-so-quick fix:
The upper eyebrow material is supposed to have a transparency map applied so that it'll look like real eyebrows instead of Play-Dough. You can find an eyebrow/eyelash transmap for Michael in Free Stuff; it's by Newt.
bubbrock316 ( ) posted Mon, 19 August 2002 at 11:51 PM
Cool, thanks for the fixes and the link Little Dragon.
fmahr ( ) posted Tue, 20 August 2002 at 2:22 AM
My document window has vanished from the interface or it's stuck up in the corner where I can't get to it's handle to drag it back to center stage. I was told that this is a minor conflict with your video driver and your system. Sometimes you will need to delete the preset pref's file and the Poser.ini. Go to Poser 3/runtime /pref and delete its contents, and restart Poser. I don't know about that video driver conflictb advice, but the following worked for me - Try the Poser 2 interface switch. Type PO2 [Enter] (the letters "P" and "O" and the number 2) on your keyboard, and to return to Poser 4 PO3 [Enter]. This puts the document window within reach, and you can pull it to the desired location.
crisjon1950 ( ) posted Tue, 20 August 2002 at 6:12 AM
Attached Link: http://205.122.23.229/ronknights/
Check out my Michael Texture Tutorial.
