Sun, Feb 2, 7:12 PM CST
Subject: Lightning in Bryce (a techinique not a question)
Enforcer ( ) posted Mon, 19 August 2002 at 9:52 PM · edited Sun, 02 February 2025 at 3:58 PM
Hi all,
The above pic is a WIP. I'm changing the sky a bit and adding more detail, but I was very happy with the Lightning effect within the clouds that I have achieved. All I've done is create a cloud from a mass of spheres (check out Brycetech for the tutorial) and then changed two of the spheres into radial lights. I changed the lights to infinite and the base color to a purplish-white.
Just wanted to share if this hasn't already been pointed out. If someone else has already given this technique away, then here's to renewing the topic.
Later...
GROINGRINDER ( ) posted Tue, 20 August 2002 at 2:39 AM
Thanks enforcer I hadn't heard of this before, although I used a similar technique for a flak burst on my hellcat picture in my gallery.
EricofSD ( ) posted Tue, 20 August 2002 at 9:28 PM
I've used rock objects instead of spheres to get a more non uniform look with less objects. Like the pegasus image in my gallery.
Enforcer ( ) posted Tue, 20 August 2002 at 10:29 PM
Good idea. I've just discovered that you can use this to animate the lightning as well. Just set the lights to pulse on for a second and then go off. Lights placed in a diffent sector of the cloud can then go on at a different time. It's a really cool effect. I wish I had time to play with this more.
