Wed, Nov 27, 1:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 27 1:15 pm)
Subject: Editing Poser Animations in Max?
designerin ( ) posted Tue, 20 August 2002 at 3:45 AM ยท edited Wed, 27 November 2024 at 11:30 AM
Can I edit the Keyframes of a Poser Animation in Max? Sometimes i need to manipulate these, but I can't do this in a good Way in Poser Pro, so I want to use Max for it. But Max shows no Keyframes in the Keyframe Editor. By the Way; another Question. Ican't render in Poser Pro Pioctures with a Background Image larger then 1200x900. If the Picture is bigger, for Example 3400x2800, Poser only renders the Models, but the Background Picture shows heavy Artefacts.
lynnJonathan ( ) posted Tue, 20 August 2002 at 4:22 AM
I think the only program you can edit poser key frames in is poser. Backdrop problem- if you have photoshop or something like then render your poser files at your size you want and then save it as a psd or tif so you can use the alpha channel in photoshop to layer the picture. In photoshop under select choose "load selction" and by defult usually it will show select alpha channel. Now you can copy or delete the empty area. I like this way so I have full contol of my seperate renders for other effects like camera blur and so on. Hope this helps.
