Sun, Jan 26, 3:05 PM CST
Subject: A question about renders.
PFJN ( ) posted Wed, 21 August 2002 at 5:34 PM ยท edited Sun, 26 January 2025 at 3:05 PM
Hi, I'm kind of new to this, and was hoping someone here could help me out. I was messing around with some stuff in Poser, and I notice that in the pre-render window everything looks fine, but when I try and render an image I get dark lines or smudges (especially around the characters mouth). I've tried to attach a couple of small images that hopefully show what I mean. (The image on the left is from the pre-render window and the image on the right (with the hair) is the rendered image. You can see dark lines/smudges around her mouth.) It really shows up alot in animations. I was just curious if anyone had any suggestions. Thanks.
Little_Dragon ( ) posted Wed, 21 August 2002 at 6:08 PM
Could be the result of the bump map, or shadows, neither of which show up in preview mode. Try increasing the size of each light's shadow map, and see if that helps.
PFJN ( ) posted Thu, 22 August 2002 at 7:42 PM
Thanks, That seems to have helped alot. PF
whitemexican ( ) posted Sat, 24 August 2002 at 11:48 PM
looks like you don't have Anti-Alias turned on. Check it in render options and it should make it look better.
