I haven't tried it, but if you set the shadow map limits in your Preferred State PZ3, it should be applied to every new scene you start. Did you re-install Poser when you upgraded your OS? That may be the reason it's changed. As far as I know, 1024 is the default limit (and 256 the default map size), and has been since Poser 3. However the limit is an arbitrary one and really only depends on how much RAM you have.
There's no easy formula, Webvogel - you just have to try it. It will depend on what models you have in your scene, and the number and size of textures. I regularly go up to 4096, on one occasion I had 4096 on two lights at once with only 128M RAM - but that was with standard Poser figures, and few textures.
Basically the limit is the maximum amount of virtual memory you have. (RAM + swapfile) In a 32bit OS you will have a hard limit at 2GB. I have actually hit that limit myself by setting the shadow map size above 9000 :-) Swapping because of this isn't too bad, so don't hesitate to use sizes well beyond the amount of RAM in your machine. IMO Playing with larger shadowsizes is especially usefull for close-up shots of a face with shadows on it from hair strands.
Attached Link: http://www.renderosity.com/homepage.ez?Who=Spanki&ViewArticle=1265
You might also want to disable "Casts Shadows" on any large ground planes i nyour scene (since they don't cast shadows on anything anyway. The link above is a mini-tut I wrote up after discovering this little tidbit (Warning: Nudity in the link)Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Hiya... Big probs. The most I can set my shadow maps to is 1024. However hard I try and however many lights are in the scene, I can't set past 1024. Sorry, but 1024 is NOT enough for a good crisp shadow... esp hair shadows on a portrait. I have had this problem since moving from Win98 to XP. Any ideas on how to sort this out?? H:)
