Mon, Nov 4, 12:21 PM CST
Bryce F.A.Q (Last Updated: 2024 Oct 30 3:44 am)
Subject: Waterline question.
Apache2k ( ) posted Fri, 23 August 2002 at 7:28 AM ยท edited Sat, 02 November 2024 at 4:36 PM
Hi, Does anybody know a good trick how to make a scene where the underwater area is visible and also the overwater level without any boolean tricks or is it just impossible to place the camera on the water level 50% water and 50% air? Thanks.
reflash ( ) posted Fri, 23 August 2002 at 12:16 PM
There's a tutorial on this in the Bryce tutorials section. The tutorial itself is located on another site at http://www.mojo3d.com/tutorials/b4splitscene.htm Hope this helps.
reflash ( ) posted Fri, 23 August 2002 at 12:23 PM
Attached Link: http://www.mojo3d.com/tutorials/b4splitscene.htm
Here's a stab at including a clickable link.
Apache2k ( ) posted Fri, 23 August 2002 at 12:36 PM
Thanks,,just what i was looking for..
reflash ( ) posted Fri, 23 August 2002 at 2:27 PM
Any time! :)
EricofSD ( ) posted Fri, 23 August 2002 at 11:55 PM
I just made two renders, camera above and camera below, then spliced them in Photoshop with some edge effects.
Apache2k ( ) posted Sat, 24 August 2002 at 7:24 AM
But i think in Bryce you can never place the camera in the center??It is always over or under the surface?
reflash ( ) posted Sat, 24 August 2002 at 1:30 PM
I believe that is the case. But as you can see above, you can do 2 renders and join them in Photoshop, Paint Shop, etc.
