Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
... notwithstanding those "hideous seams," please repost when you get your problem fixed. It looks EXCELLENT!!! (damn near phtographic!) BTW (#2) - The same problem occurs when a Poser figure is imported into RDS using a perfectly good texture map. The problem is in the rendering, NOT the texture map. I have not pursued a fix for the problem in RDS because I do not use RDS for renders, so I regret that I cannot offer any kind of solution. Lyrra's suggestion to ask the question in the "Cinema forum," is a good one. cheers, (anyway) dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Yuma is a beautiful map, professionally done... which renders perfectly in Poser 4.3 and Vue 4... I bought this map after seeing Yuma in art for a very long time, and have not seen anyone else have these problems.... so it's probably the software? Lyne
Life Requires Assembly and we all know how THAT goes!
I would have to agree! It must be the software. I've rendered Yuma from just about every angel and lighting in both Poser4 and Vue4 and there is no seem problem. Lyrra is correct, they don't match where the seems are on Victoria. There is no seem on her cheek or running across her breast. Stefy's textures are some of the best there are.
It fixed the light dots on the wall, too. SHONNER http://www.shonner.com
