Fri, Jan 10, 9:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Help! Problems importing 3DS files into Poser.
riskebiz ( ) posted Sat, 07 September 2002 at 9:55 PM ยท edited Fri, 10 January 2025 at 8:49 PM
Hey, when I try to import a 3DS file into Poser 4 Pro Pack (currently running Pro Pack Service Release 3, though I was having the same problem with the earlier version), the dialogue box that comes up says "Now exporting 3D Studio file..." which is weird since I AM IMPORTING the file and then a dialogue box comes up saying "Error in plugin 'File Format 3D Studio". It does that when it says it's about 54% complete. Help! Anybody know why importing 3DS files into Poser isn't working anymore? I know in the past I've imported 3D Studio files into Poser just fine. This is weird.
brian71us ( ) posted Sat, 07 September 2002 at 10:02 PM
Have you tried another 3DS file, one which you were able to import previously? Brian
riskebiz ( ) posted Sat, 07 September 2002 at 10:08 PM
I have tried several others. This particular one is an .obj file that I exported from Poser into a 3DS file and tried to re-import it back in. It's actually been a while since I've been able to import a 3DS file into Poser, I just decided to import object files instead (though I had been able to import 3DS files before and I can't remember what Poser upgrade caused it to stop working because I don't import 3DS files that often), so I've ignored the problem until today ... sorry to say. It's just that the file size of a 3DS file is significantly lower and on this particular Poser document I'm working on kind of needs the benefit of a 3DS file size.
ronmolina ( ) posted Sat, 07 September 2002 at 10:09 PM
You can not import all Max files to Poser or 3DS for that matter. It has to be the base model nothing else. Ron
riskebiz ( ) posted Sat, 07 September 2002 at 10:13 PM
Simple 3DS files shouldn't be a problem though, should it? If I export an OBJ, 3DMF, DXF or a 3DS file from Carrara and Poser supposedly has plug-ins to accept these files, why is it that it suddenly won't accept a 3DS file? It'll take all the others.
ronmolina ( ) posted Sat, 07 September 2002 at 10:39 PM
A basis 3ds file should not be a problem but are in some cases. The models can get really screwed up. Export as dxf and it should be okay. Ron
