Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 27 2:29 pm)
Nope :) Also you guessed on the 5 doors allready. It are 2 questions so 1 answer to one of them makes a winner. So normaly you have 3 guessing allready for today but cause i asume you did'nt get that right you may do 1 more guessing for today either on 1st or 2nd question. It might be good to wait untill the tips come :) Sprinter
Ok its your choice but your fault is forgiven ;) So if you like 1 guess is still possible. Here are 2 tips. 1) TLR 2) There are 6 rooms and a garage 3) This is a hard tip but if i explain otherwise i might just tell the answer lol, A combination could lead to the right one. Hopefully the tips are not to hard and also not to easy. Good Luck Sprinter
The doors are higher then 5 the tip 3) might be misleading. The tip 3) points to posts in this treath. As for the name you might think not so big. Thats should do it for today :) I'll check again in a bit before i go to bed. When no correct answer when i wake up tomorow i'll place some more hints :) Sprinter PS Thanks for the nice comment DragonGirl :)
