In fact, you can use any 3D primitive from any program (sphere, or others). You just have to edit the object to disable smoothing informations. For one of my first picture in Vue 3.0, I loaded a 3ds skull, applied a crystal material and disabled smoothness... it looks great ! Hope it can helps... Argentium Thri'ile
Myske / MightyPete : I'm going to look for that, but it depends how they look like. :) Thanks. Sittingblue: Thanks. YL : hmmm, got my doubts.. :) Thanks anyway. A.T. : Then I would have to make the hole crystals in, another software that I don't have :.( Not sure they can be made in Metasequioa. Thanks. :)
YA there actually pretty basic set. I was thinking you might be able to use the crystal shape. You need the big sets to do a really good job and then it sucks cause it's a against the usage rules. I was thinking Shape 1 would work if you flipped it over and stretched it out a bit. That would be one crystal 12 polygons. I just looked in the free sample pack again. There is lots of shapes there that will work you just have to flatten them a bit or stretch them a bit. Look carfully. The pill shape ( Shape 1768 ) flattened x wise. Or shape 122 sidways and stretched a bit z Some shapes will even work as is. You can use Shape 1644 as is for the ball. One thing if you stick to the free set you can also stick it free stuff later for others to download. Renderosity will frown on giving away parts of the other sets. Things need to be done before stuff like that can happen.
Attached Link: 3D Lapidary
Try 3D Lapidary - lots of free gem models in all kinds of faceted cuts - 3ds models I think - maybe they are dxf. -dgThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
