well, I'm afraid I can't realy help you with your problems, but I think I CAN explain your RAM situation. what it sounds like to me, is you computer has 128 MB RAM, and 24MB of that is shared with your video card(most likely onboard video, rather than an actual card). sorry about the rest, big_hoovie
Aye, battle angel, are you running Bryce 4? It's not a RAM issue, I use Bryce 4 on my work computer, a Pentium II/266, with only 64 MB RAM. It runs beautifully, and has never, ever crashed. But at home, on my larger/faster computers, I use Bryce 5 (Lightning rules!). What you're probably dealing with is a corrupted registry, or maybe you just need to update your Direct-X drivers. If you ARE using Bryce 5, go download the update from Corel.com, and it might help you. Does your machine freeze up with other applications? If so, I'd suggest running Windows 98 setup off of your disk, and if that doesn't fix the problems, purchase Norton Systemworks and have it "HEAL" your machine... It can work wonders on corrupt registries.
i was able to save some of the files but not all. i guess i will mis this months entry. but alas i have tolook at the positive side of things. i get to start with a whole new world more or less im just gratefull i didnt loose all my mats cuz that would have been a bitch to replace. thanks for your help all.
im having a problem with bryce. it keeps freezing up on me causing me to reboot my pc plus anytime i try to load anything from the create litlle triangle menu (sorry i dont know the term for it) it freezes up also ive saved all my work on a cd uninstalled bryce and reinstalled and loaded the work as new but same problem. im running a p3 800 with 104 megs (dont ask how dont know myself) any suggestions???? please help need my bryce fix
