kao, I haven't defragged my drive yet to test (it's too big to do on the fly,)and I don't see why a shared directory would give P5 any problems. And finally, my machine has RAID. I've been playing w/ the prog for several hours w/o any major problems....besides sucking up memory that is. I hope this helps. --lb
LB, Thanks!!
CL's website on C/R seemed to indicate that the registration was tied to the instance of the state of the disk on which P5 is installed. (The reply from CL Tech said basically the same thing.) Any action changing that instance would inactivate the keying. My Windows XP box is stripped down, barebones. Almost all my file management is done via crossover to a LINUX/RAID box running SAMBA. (My net IS my computer.:-)
Poser 1,2,3,4 all worked happily this way, but was looking like P4 was going to be my final iteration. ---kao
Having had my question about Challenge/Response kicked back as "irrelevant" by CL Tech support, I am hoping someone who owns P5 will be kind enough to answer any of the following questions:
++ Does your copy of P5 still work after you defragment the local hard disk on which the application resides?
++ Were you able to load and run P5 from a shared directory?
++ If your system storage is a RAID, were you able to install, register, run P5?
Thanks!
