Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
I have this hair and I tried it in poser 5. It loads all right. It is located in my poser 4 runtime directory. I told Poser 5 where the runtime folder was. The hair loads fine. But when I try to render, it says it is loading the textures and then it is loading the objects and that's where it seems to stop. Maybe I'm not waiting long enough. I waited three minutes, but nothing seemed to happen, so I clicked on cancel and then the Poser menus disappeared and it said that poser wasn't responding. I was using the new renderer in Poser 5. I've tried this several times with the same result. I really like this hair. Has anyone else got it to work? I figured I try the poser 4 render and see if it works there and then maybe I'll re-install it in poser 5 to see if that makes any difference. Thanks. On a side note, if you're one of the people who doesn't get any menus when visiting the new DAZ store, try using the search engine. It works for me. At least I can get to the product. The only other really bothersome thing that happens is that I can't seem to load more than one thing to my shopping cart. When I add the second thing, it replaces the first. But I'm sure they'll work it out. Kevin
