Wed, Feb 12, 9:14 AM CST
Subject: Silly Question
Angel1 ( ) posted Fri, 13 September 2002 at 8:26 PM ยท edited Wed, 12 February 2025 at 9:00 AM
I want to transfer all my P4 stuff to P5 - my silly little question is which of the directories do I use? The one for downloaded content or the one the most resembles where P4 items went? I sure you guys understand this Thanks to all who answer Angel1
....Now Bring Me That Horizon....
Send IM | Gallery
HandspanStudios ( ) posted Fri, 13 September 2002 at 8:37 PM
I think either will work but I myself am only using the main directory. It makes zipping files easier than using the separate 'downloads' one. Like we didn't have enough folders to keep track of ;-) before.
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
Jcleaver ( ) posted Fri, 13 September 2002 at 8:38 PM
You can add your present P4 runtime to your palette, thereby not having to copy it. There is a thread somewhere here, probably 250 posts ago, that explains it in detail. It is in the manual also.
Angel1 ( ) posted Fri, 13 September 2002 at 8:39 PM
Did you just copy all of your p4 files over as is??? Angel
Send IM | Gallery
PabloS ( ) posted Fri, 13 September 2002 at 8:52 PM
You don't have to copy at all. Just link to it. The function is in the library. It was covered here yesterday, I believe. Sorry, don't have the url.
wdupre ( ) posted Fri, 13 September 2002 at 11:17 PM
very simple, go into your library find one of the up arrow folders(they're in the top of every library then double click it as many times as it takes to get to the page with the download and P5 folders. at the bottom is a + and - click on the plus then browse in the window to your P4 runtime folder click on that and hit ok and your P4 library is added to the library list no need to load all your stuff you can access the P4 directory from your p5 library. you can also create new librarys wherever you want all accessable from the main library
Angel1 ( ) posted Fri, 13 September 2002 at 11:29 PM
Thank You all so much for the help :} Dupre..you are a sweetheart :}
Send IM | Gallery
