Tue, Feb 4, 10:47 PM CST
Subject: Okay..Just me or what? - Poser5 object exports
Hdrider ( ) posted Thu, 12 September 2002 at 10:52 PM ยท edited Tue, 28 January 2025 at 6:49 AM
Hello, I've attached a couple of images that shows the problem I'm having with P5. Like I said, is it just me or what?
Any help appreciated.
Thanks...hdrider
No good deed goes unpunished ...
Hdrider ( ) posted Thu, 12 September 2002 at 10:53 PM
The other one.
pdxjims ( ) posted Thu, 12 September 2002 at 11:55 PM
Heck, I've always had that problem in P4. If someone knows a solution, I'd love to know it too! I always thought it was just something you lived with.
ilr ( ) posted Thu, 12 September 2002 at 11:58 PM
I had this problem. Running winXP screen resolution 1600x1200. solution: I opened another application (in my case it was windows commander, but it can be anything else. I can open windows explorer, or my computer.) Then I start the export process in Poser and when the dialog box appears I switch to that application. Just select it on the taskbar or use alt+tab. then i select poser again. this time the dialog box allows you to check/uncheck whatever you want. once the export is done you can close that application. sorry for a messy explanation, it's difficult to write so early in the morning.
pdxjims ( ) posted Fri, 13 September 2002 at 12:43 AM
Thank you! Thank you! Thank you!
ilr ( ) posted Fri, 13 September 2002 at 2:29 AM
Assume it works? Congatulations, then.
EricofSD ( ) posted Fri, 13 September 2002 at 2:33 AM
When I first installed P4/pp I could check/uncheck all the boxes. But lately some have not been working. Thanks for the open other app thingie, i'll have to try it. someone suggested a place on 'osity for work around threads. That would be great.
c1rcle ( ) posted Fri, 13 September 2002 at 4:53 AM
never had that problem but then I have several things open all the time & switch between them a lot so I wouldn't notice it even if it did happen to me ;)
OpticalSingenoid ( ) posted Fri, 13 September 2002 at 8:51 PM
Another trick to the same problem: Just click on the Task Bar(On a PC), then go back to poser! Works everytime for me! I'm just sad that my brother won't buy me Poser5 'till my birthday(December) :-( Anik
Hdrider ( ) posted Sat, 14 September 2002 at 9:07 AM
Thanks All,
These work arounds are okay for now but I hope that this bug is on the list of fixes that CL is compiling. Hopefully close to the top.
Later...hdrider
