Artist 3D, Windows 9x doesn't have this capability built in. However, there's a freeware utility called "Process Explorer" at http://www.sysinternals.com that might do the trick. For those of you on Windows 2000/XP, there's another way to set the priority for a program without going through the taskbar or CTRL-ALT-DEL. You can make a batch file to do it for you. For Poser, create a new text file and type the following: start /high Poser.exe Save this in you Poser.exe directory as "RunPoser" or something like that and rename the .txt extension to .bat
Hmm, I've never had any problems personally. I usually run Poser (this is Poser 4, mind you), Photoshop 5.5 and Internet Explorer at the same time. The only thing I can say is if you have crashes or such, either don't multitask OR replace "start /high Poser.exe" with "start /abovenormal Poser.exe" Of course, system specs are also a consideration.
c1rcle when you say "Anything higher than above normal can potentially crash windows if you have anything else running at the same time as poser", are you refereing to your virus software, or other applications? Sharen PS: there are always things running at the same time that you don't know about right?
Maybe it's time for someone with a bit more experience with computers to respond ;-) The priority settings have nothing to do at all with memory. You cannot assign a program more memory in Windows. That advice is strictly for Mac users. When you start a program in windows XP it will automatically have all memory available that you have installed in your PC. (well actually 2GB, but let's not go that deep into things :-)) So you don't have to do anything about that in windows. Setting a higher priority for a program has to do with the CPU time it receives. When you run just one program it has all CPU time available to it. But when you run multiple programs the CPU time is distributed among them. (They each get a short moment to run on the CPU and then have to wait for the others) When all programs have the same priority, the CPU time will be distributed equally to them. When you select a higher priority for Poser, it will get more CPU time than the other programs. By default Windows XP will already give the foreground applications, (the one you work in at that moment) a higher priority than the background applications. So if you don't run other CPU-hungry applications in the background you won't see much difference when you select a higher priority to Poser. It's only usefull when you run something that uses lots of CPU in the background. (Like a Bryce render) and don't want Poser to be slowed down by it. Hope this helps. Marc
Hey, c1rcle, I wrote a game for the C64 once. Published it, too. Ever heard of "Tunes 'n Trivia?" I did that (barely broke even tho so I quit). It was on TV once. mjtdevries: LOL! It's obvious you're more experienced, you didn't mention a problem with P5. And: "You cannot assign a program more memory in Windows" I thought that myself but, with my level of experience being what it is, I figured it best not to say anything. Thanks for stepping in.
Okay, I know I can do this just don't know how I can allocate more memory to Poser.exe for it to run better....can anyone help, I read a post today but no description was given...Sharen
