Have you tried opening the cr2 file,in a text editor, for another clothing figure then changing the geometry references to point to your geometry file(should be 2 listings)? I used parts of the catsuit and miniskirt to make a long sleeved mini skirt this way and it works fine, just when you save it it saves as a text file all you have to do is change the ".txt" to ".cr2" manually and if you have a .rsr file for the dress delete it and load your .cr2 file from your library in poser. by the way nice dress reminds me of the witch? in snow white.
Yes Markm, Tried the trick of using another "cr2" file. I've got much closer, But things are still screwy. The forearms, hip, chest and thighs work, (well somewhat), but I can't get the shldr's and collar's to fit. I'm sure eventually someone will come to my rescue. Or maybe by then I'll figure it all out. James
