Thu, Jan 9, 8:06 PM CST
Subject: Poser5 and Animations
phoenix4 ( ) posted Fri, 20 September 2002 at 3:40 AM ยท edited Thu, 09 January 2025 at 8:03 PM
I have tried twice(for many hours).. using FireFly renderer in Full production mode to make a small animation (30-90 frames)
I created an avi file, but when I went to play it, it was just blank!!!.
no models.. just the back ground colour.
Any ideas??
Neftis managed to create some animations displaying the poser5 hair dynamics... so it must work??
ronmolina ( ) posted Fri, 20 September 2002 at 9:37 AM
I have had some problems in this area myself. Could be our settings. Nerd posted some suggestions in an earlier post that I am going to try. What is crazy here is sometimes it works other times it does not. Ron
TalleyJC ( ) posted Fri, 20 September 2002 at 9:53 AM
Make sure your camera isn't below the floor plane... If the camera goes below the floor you'll be able to see through it while working, but it will go solid in the render
TalleyJC ( ) posted Fri, 20 September 2002 at 9:57 AM
oh also, if you are using a codec that has a horizontal and vertical limit that doesn't match your render you'll get that.... I belive that Indeo for example must have an aspect ratio that are multiples of 4.... (a lot of codec are based on this).... makesure your document and render window sizes are mults of 4 (640 x 480 or 320 x 240) etc...
phoenix4 ( ) posted Fri, 20 September 2002 at 9:02 PM
My Camera was just pointing at the figures face. I also tried rendeing in full frames uncompressed (ie no codec) and still the sme result... What I did end up doing was just creating a jpg sequence, tying them together with another program and adding the sound after. I must be doing something wrong though?
