Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
heya; its supposed to do that. like if you put a prop hat on somebody and saved them, they keep their hat. and earrings and belts and swords and whatnots. the patch 117+ lets you save more than one figure into the library (like conforming figures), you might try that (if you don't have beta-patch-a-phobia. :) )
I made a small dual spherical transparent prop that barely "covers" each eyeball to give the whites some glass like qualities. Now I've noticed that the props geometry has been stored in the cr2 file sort of like deltas for a morph, and I don't even need the prop object file anymore! Also this happened to the "base object" from "Nene 411SE" (by Kozaburo and Yamato). I am sure this happened after saving the figure to the library, then using then using that saved cr2 file from the library. Can anyone tell me how or why this has happened? I would like to have some control over this! Anyone?
