Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
I am in the process of creating a list - which I will send along to CL-tech, but that never got me replies in the past, so I thought I'd start here ;).
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
JeffH is right; the selection marquee looks bad when you load from the alpha channel, but it still works properly. If you invert the selection (SHIFT-CTRL-I), the marquee suddenly looks perfectly normal. The alpha channel itself seems to be fine. Could it possibly be a display issue with Paint Shop Pro, instead? Does the same thing happen in Photoshop?
It might look correct if you invert the alpha, but there is background color of a very low opacity data left in the area that appears transparent. Run your eyedropper tool over the flaky areas in the mask after you use the mask to remove the background and see how there are rgb values there where there are none in the areas that are truly transparent. That keeps one from cleanly cropping to the outline of the figure rendered. There is no easy way to bring the alpha selection up around the the edges of the object. I have been rendering twice if I had to use the firefly rendered, the 2nd time with Poser 4 renderer. It might save the alpha inverted sometimes, but it is clean and the alpha in tifs or psd files can be re-inverted in my software.
Oh for crying out loud, what next? As far as I'm concerned, this one bug makes Poser 5 useless to me until it's fixed. I've purchased every previous version Poser sight-unseen, but I'm very glad that I took a chance and waited on this one. The bugs and flaws are one thing, but how a company can forget to include the figures' texture templates and other content on the CD is beyond me. Thanks for pointing this out Spanki, I appreciate it. Take care. SnowS Hoping his pictures are worth 1001 words.
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
