Attached Link: http://www.shawstudio.com/
Here you are - Follow this link, then click on "P4Woman TShirt with no end caps". Instructions: * Click on link and save the ".pcf" file anywhere. * Run ObjactionMover [FREE- click on link to Sandy Lodge, if you need it]. ** Select "decode" radio button. ** For seed file, browse to "..RuntimeGeometriesPoser4ClothesShirtsblwTshirt.obj" ** For Difference file, browse to that ".pcf". ** Click "Convert". * Import the resulting OBJ into Poser 5. Now you can clothify it. - - - - - Tech Notes: CAUTION: that's bl "w" for woman. The first time I tried it, I accidentally used "m" for man. Didn't work. I stripped off the end caps in LightWave, then ran through UVMapper to make sure it was a good file format. I tried simulating this in cloth room with Judy. Poser 5 kept hanging on me. (WinXP Pro, Athlon 1.4 GHz, 512MB RAM) Let me know if you succeed! shirt is too small. Yet resizing made it too baggy. - - - - - SHRINK-WRAP: Idea that I was trying until I gave up due to Poser hangs: a la previous thread about getting cloth to work with Fairie morph, but change SCALE over time instead of using a morph: * start with scale 110% AND z-scale 110% on frame 1, going to normal 100%s on frame 30 -- to see if cloth will adapt to the gradually-changing scale. If it works, the result would avoid the "bagginess" of using a large scale! -- ToolmakerSteveThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Does anyone know where I can find a simple t-shirt (female) that I can use to clothify. The P4 t-shirt contains caps. I haven't actually tried to remove them, but I'm assuming it's a tedious job. So, I'm looking for one that I can use as is to clothify. Thanks!
