Fri, Jan 10, 2:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: I need help with a wounded figure!
TheWanderer ( ) posted Sun, 22 September 2002 at 6:03 PM ยท edited Fri, 29 November 2024 at 4:38 PM
Hi I have an idea for a render in P4 but to make it work I need a prop which I dont know how to make and well I was kind of hopeing some kind sole would point me in the general direction. what I need is a bandage, you know the kind of thing you would wrap around a damaged limb. I have tried to modify the texture of the character but it doesn't look quite right and my computer modeling skills aren't up to making it myself. So I would apreciate any assistance btw it needs to be for a big arm/leg that sort of thing. anyway thanks in advance Dave
lesbentley ( ) posted Sun, 22 September 2002 at 8:08 PM
Only thing I can think of as a quick easy fix is something like in the image above. I took a Poser4 torus prop, played with the yScale and Fatness dials till it was more cylindrical. then I saved a copy to the pallet and imported two copies back to the document. I played with the translations and zRotate to offset the copies a bit, until it looked like the picture, applied a texture that looked vaguely cloth like, and exported the whole thing to an obj file with the default save options.
If it doesn't fit using the scaling dials you could use magnets to spawn some morph targets.
It's not great, but it's easier than learning to use a modeling app ;)
lelionx ( ) posted Sun, 22 September 2002 at 8:14 PM
i think cooler has a cast at 3d commune
Little_Dragon ( ) posted Sun, 22 September 2002 at 9:37 PM
Needs bloodstains. :)
lesbentley ( ) posted Thu, 26 September 2002 at 7:17 PM
Dragon, you volunteering to be a donor ;)
