Tue, Feb 25, 10:27 AM CST
Forum Moderators: RedPhantom
Subject: Texture problems
CocaColafreek ( ) posted Sun, 22 September 2002 at 12:37 PM · edited Mon, 03 February 2025 at 8:59 AM
Hello, I am having trouble with my texture, I am trying to make the lower part of the dress dissapear, i guess you can say :), but when i put it in the transparency map in you can still see the bottom part! what am i doing wrong? thanx for the help
doldridg ( ) posted Sun, 22 September 2002 at 12:50 PM
Did you check the falloff? It should be zero.
c1rcle ( ) posted Sun, 22 September 2002 at 12:51 PM
you need to set the reflective colour to black to get rid of the wispy bit ;), this is poser4 right? if it's poser5 then I'm not sure what you do. Rob
Tisa ( ) posted Sun, 22 September 2002 at 12:52 PM
In the materials editor (drop down menu Render/materials)make sure you have highlight size set to 0%
CocaColafreek ( ) posted Sun, 22 September 2002 at 12:59 PM
thanx but istill kinda get a highlight on the part that is invisible now, how do i fix that? and yes i did set the highlight thingy to 1 (cuz it wouldnt go to 0)
CocaColafreek ( ) posted Sun, 22 September 2002 at 1:01 PM
forgot to set the highlight color to black let me see if it works now:)
CocaColafreek ( ) posted Sun, 22 September 2002 at 1:02 PM
i mean the reflective color
jerr3d ( ) posted Sun, 22 September 2002 at 1:11 PM
if the above don't fix it, go to photoshop and check your transMap, if you have your black set to anything less than 100% it will show 99% black looks pure to the eye, but not to poser!
Kendra ( ) posted Sun, 22 September 2002 at 1:48 PM
Your transmap must have a black background and the transparancy settings set to 100%.
...... Kendra
1Freon1 ( ) posted Sun, 22 September 2002 at 5:17 PM
Heh.. When I first looked at the pic I thought "Hey, thats a cool lookin dress!".. Then I read your message.
ssshaw ( ) posted Sun, 22 September 2002 at 10:22 PM
Poser 5 vs. Poser 4 shouldn't matter. To clarify Kendra's comment, Did you set the MIN transparency to 100%? That is, don't set just the MAX transparency, make sure BOTH are 100%? If that's not it, then as mentioned, your transmap black must not be quite zero.
Lucy_Fur ( ) posted Mon, 23 September 2002 at 1:58 AM
Yes, like ssshaw says - make sure your transparency MIN & MAX both are set to 100% and having the transmap black is vital too :)
wtsmith ( ) posted Mon, 23 September 2002 at 11:44 PM
I got that same effect and my falloff wasn't at zero
Lucy_Fur ( ) posted Mon, 30 September 2002 at 4:01 PM
OH - one thing (maybe) - finally occurred to me make sure you UNcheck the box that says - apply texture to highlight (or similar) If this comes late and/or you've gotten it figured out, sorry for me sounding dumb here G
