Thu, Dec 26, 3:41 AM CST
Subject: "Real World" Measurements in Poser 4 (revisited) ... again ...
geep ( ) posted Wed, 25 September 2002 at 5:30 AM · edited Thu, 26 December 2024 at 3:34 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Wed, 25 September 2002 at 5:37 AM
Attached Link: http://www.grfkdsgn.com/prop.html
You can also get it here. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TrekkieGrrrl ( ) posted Wed, 25 September 2002 at 6:06 AM
Uhm do you by any chance have plas of doing a similar prop in metric measurements? I haven't got a clue of how long a foot is and with my very poor math skills I'd probably mess it up completely if I should do the calculations myself. Thanks in advance ;o) ~TrekkieGrrrl
arrh...plas = plaNs
FyreSpiryt ( ) posted Wed, 25 September 2002 at 6:25 AM
TrekkieGrrrl, if it helps, 1 foot is 12 inches and 1 inch is 25.4 mm. The math you still have to fight with, though.
yggdrasil ( ) posted Wed, 25 September 2002 at 7:49 AM
1 foot ~ 30.5cm (approx) 1 metre ~ 39.35 inches Being in the UK, I'm forever converting back and forward. -- Mark (1 mile approx 1.6 km; 1km approx 0.62 miles)
Mark
Misfire ( ) posted Wed, 25 September 2002 at 9:34 AM
The standard inch is defined in terms of the standard metre. 1 in == 2.54 cm (exactly).
ockham ( ) posted Wed, 25 September 2002 at 12:00 PM
Ern: Until somebody recalibrates the ruler itself, one way to avoid constant math is to set the ruler's scale to 32.81%. Each division will then be one decimeter (10 cm).
My python page
My ShareCG freebies
zalmegra ( ) posted Wed, 25 September 2002 at 2:45 PM
Hmmm.....another way is to adjust the floor tile, say that every 3 squares is actually a meter, and go from there. Make the cube prop into a ruler that matches the squares....etc. I've been using Lightwave for a short while and even though it will convert between metrics and feet and inches, I've found that the measurements really are mostly practical when building a scene, but the viewer of the final render will have no way of really knowing if everything is to scale anyway, (unless you are designing something like a court re-enactment or something like that.)
MaxxArcher ( ) posted Wed, 25 September 2002 at 5:45 PM
Geep, I am not trying to be smart, but shouldnt an inch be divided into 6 or 12 subdivisions instead of the 10 you are using in your scale? (Im Dutch using the metric system, obviously I could be wrong...) MaxxArcher
geep ( ) posted Wed, 25 September 2002 at 7:05 PM
Hi Max,
You are NOT being "smart," and you have asked a very good question.
I am glad you asked the question because I am sure there are others who would like to know the answer, also.
The answer is ...
... the English "inch" is normally divided into:
halves ....... 1/2
quarters ..... 1/4
eights ....... 1/8
sixteens ..... 1/16
thirty-seconds 1/32
(etc.)
Thus:
This system (i.e., dividing in "half" each time) does NOT lend itself to work well with the Poser decimal (base 10) system. (e.g., 0.000)
That is why I have divided the English "inch" into 10 parts, and NOT quarters, eighths, sixteenths, etc.
It is interesting to note that, even in the good ol' U.S. of A., the "Engineering" type of scale (or ruler) is produced with the inch divided into 10 parts - and NOT 2, 4, 8, 16, etc.
I hope this answers your question.
BTW - I just did a post for the METRIC system using Poser's GROUND.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 26 September 2002 at 12:17 AM
..."Real World" measurements .... for my METRIC friends. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
