Sun, Feb 16, 5:39 PM CST
Subject: Problem importing models from Celtic Cross 3D
Erlik ( ) posted Wed, 25 September 2002 at 10:20 AM · edited Thu, 13 February 2025 at 3:28 PM
After AgentSmith posted the list of free software, I downloaded Celtic Cross. I mean, I like the knotwork. :-) Anyway, after I created a model in CC3D, I exported it first as an OBJ. Got "bad i/o" whatver error message. Somebody posted a fix, IIRC, here for that. Could you do that again, please? Then I exported the model as DXF. But when I imported it into Bryce, I got something strange. The model loses the polygon count, although Bryce reports anything from 5 to 27 thousand polygons, depending on the number of sides I use in CC3D. So, instead of smooth(ish) ropes, I get something that looks like it's made from rotated cubes. You see the edges. Regardless of smoothing or unsmoothing. Unfortunately, I'm not at my computer, so I cannot post a pic. I'll try to do that when I get home.
-- erlik
Erlik ( ) posted Wed, 25 September 2002 at 1:37 PM
Here's the pic
-- erlik
AgentSmith ( ) posted Wed, 25 September 2002 at 1:54 PM
Attached Link: http://www.uvmapper.com
That's crazy, never seen that happen before. The fix, that I use anyway, is to run the .obj through "UVMapper Classic". Just load it up, then re-save it. Usually works.
AgentSmith ( ) posted Wed, 25 September 2002 at 2:13 PM
I brought up my celtic knot program and tried it, no problems with .obj or .dxf in Bryce. You may want to uninstall/re-install the Celtic Knot Program, I guess?
lsstrout ( ) posted Wed, 25 September 2002 at 4:41 PM
Erlik, It may not be what you wanted, but it does look interesting. It reminds if Escher's work. Lin
DigitalSteve ( ) posted Wed, 25 September 2002 at 5:24 PM
I'm guessing here but it's to do with dxf'file versions'.
Try this.
Export from knot as dxf, run it through crossroads
http://home.europa.com/~keithr/crossroads/
export as 3ds then import into bryce.
Erlik ( ) posted Thu, 26 September 2002 at 5:26 AM
I'll try that when I get home. I tried running an OBJ knot model through UVMapper last night. It said that the model doesn't have UV coordinates and asked me to assign a New UV Model. I put Planar and got a line. Ew. Strange.
-- erlik
AgentSmith ( ) posted Thu, 26 September 2002 at 8:54 AM
Perhaps if you had the 3.37 version of celtic knots?
Erlik ( ) posted Thu, 26 September 2002 at 4:35 PM
I downloaded the latest one. I tried Crossroads. It imports dxf, says "something percents ... done" and then nothing appears on screen. Absolutely like I didn't try to import anything. OBJ is imported, but just one strand from several that make a figure. And also Escher-like, even before I convert it to 3ds.
-- erlik
EricofSD ( ) posted Thu, 26 September 2002 at 11:27 PM
Download it again and install after removing your existing celtic knot. I have not had this problem either and wonder if you got a corrupted DL.
Erlik ( ) posted Fri, 27 September 2002 at 3:53 PM
AgentSmith was right. I didn't have 3.37. Installed it and everything works as it should. Thanks.
-- erlik
AgentSmith ( ) posted Fri, 27 September 2002 at 6:17 PM
Wohoo! Alright!
