Mon, Feb 3, 9:44 PM CST
Subject: new and learning cartoon effect
WLC ( ) posted Thu, 26 September 2002 at 6:10 AM ยท edited Mon, 03 February 2025 at 6:58 PM
How do you get cool cartoon effect mines always look terrible.
Little_Dragon ( ) posted Thu, 26 September 2002 at 3:02 PM
Approach #1:
Use the Cartoon w/Lines document display mode (CTRL-7).
Advantages: cel-style shading with lines
Disadvantages: no textures, transparencies, bump maps, or shadows
Note: From the Display menu, you can set the display mode for individual elements (figures, body parts, etc.) of your scene, allowing you to mix-and-match modes simultaneously. So you could have texture-shaded eyes on a cartoon-shaded figure. Also, Cartoon w/Lines looks better after you antialias the document window.
Approach #2:
Play around with the Sketch Designer. I don't think you can truly achieve a smooth cel-like cartoon render with the thing, but it's great for creating renders with a rough, penciled or painted appearance.
Approach #3 (Poser 5 only):
Learn how to utilize the Material Room's shader nodes, especially the Toon and Edge Blend shaders.
Advantages: Can be rendered normally, with textures, transparencies, bump maps, and shadows.
Disadvantages: The lines aren't quite as bold as those in Cartoon w/Lines mode.
Note: Disable the regular Diffuse_Color channel by setting its value to zero, and plug the shaders into the AlternateDiffuse channel instead.
