Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
it is a material setting and a bit of texture shine. I'll do a lip one next
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Your tips are really some of the most useful I've seen. I also like how you fit everything into one image! That way I can just save it like any other picture and open it up while I work. :) Excellent texture too, is that your own? Thanks again for sharing, take care. SnowS Hoping his pictures are worth 1001 words.
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
Actually, I do have a couple of little Photoshop-related questions you might be able to answer if you don't mind. :) - I've downloaded brushes for PS7 that do not "build up" when you paint, but every custom brush I try and create builds up like an airbrush even if the airbrush option is off. Do you have any idea what I might be doing wrong, or how to create a non-build-up brush? - Is there any way to have a pattern rotate as you paint with the Pattern Stamp too? I can get the brush to rotate, jitter, fade, and everything else under the sun, but I've never seen a way to make the pattern rotate with it. Thought maybe there could be some unusual way to make it happen. ;) Anyway, thanks for your time and your very useful tips. Take care. SnowS
that is V2 in P4
-Anton, creator of
since 3-13-07
Uv mapping a figure.....hmmm. Hi res like dina is really tough. Normally you would start with a very lo res version, map that(which is easier), and then res it up later. Alot of Uv mapping is really mive point by point and using a checkerboard pattern to check for distortion. I will work on a tutorial.
-Anton, creator of
since 3-13-07
Attached Link: Image I used this in......
Sometimes no matter what you do Poser just doesn't want to make shadows where you want them. Here is an easy way to add depth and realism to the eyes. Just make sure the shadow is not too far or too dark. Anton PS: If you ever want me to post something specific let me know.-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
