Attached Link: http://www.armanisoft.ch/webdesign/default.htm
Explain that? "from up-side down in dxf or 3ds"
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Ah, I understand what you mean now. Do you want the final lettering to be in 3D? (I assume you do) One thing you can do is to... Make your lettering in Elefont, import it into Bryce... Rotate your lettering group to X = -90 degrees. (This will face your lettering towards the camera) Then ungroup your lettering, but do not deselect any! Rotate the letters to Z = 90 degrees. Re-group letters. They are now going "up and down" You may have to re-position the letters a bit to make them more aligned, but this is the only solution that popped into my head. AgentSmith
Freestuff | IMDB
Credits | Personal
Site
After that... Take those re-grouged letters... Rotate the group to Z = -90 degrees (The letter group will now be vertical) Ungroup the letters again, and again do not deselct any! Click on the little "A" for attributes In the field for "Origin - X" type in the number 0 (zero) This will center all the letters at X & Z = 0 (zero) Again, you may have to adjust the letters (now it will just be vertical adjustment) AgentSmith
Freestuff | IMDB
Credits | Personal
Site
Hi everybody.... Is there a program like Elefont to create fonts from up-side down in dxf or 3ds ect ect Thank you... thedouf
