Sun, Nov 10, 3:44 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 3:42 pm)
Subject: Millie neck
Al ( ) posted Mon, 27 March 2000 at 3:38 AM ยท edited Sun, 10 November 2024 at 10:24 AM
In various poses I get this strange black triangle. Anybody can tell me what's the problem? Thanks AL
Trask ( ) posted Mon, 27 March 2000 at 3:46 AM
The problem looks like Zygote didn't test Millie very well if you ask me. It might be fixable with a morph target on that "face", not sure.. I've heard Millie is not 3DSMAX friendly, if so when I do get her, I won't be able to do nothing about it probably.
bushi ( ) posted Mon, 27 March 2000 at 3:49 AM
Yes, I have seen this too. It seems that if you twist the new upper neck group much past 8 degrees you get this result. It looks like a flaw in the model but I need to work with it some more to figure it out.
Al ( ) posted Mon, 27 March 2000 at 4:26 AM
I have installed a fresh copy of Poser 4 software on a different system to be sure that it wasn't a problem due to a faulty installation. Maybe Zygote can find a solution... AL
JeffH ( ) posted Mon, 27 March 2000 at 4:51 AM
Send this pic to Zygote.
Al ( ) posted Mon, 27 March 2000 at 4:52 AM
JeffH: It is exactly what I have done! Thanks AL
rtamesis ( ) posted Mon, 27 March 2000 at 9:17 AM
Try as I may, I can't get this black triangle to appear on her neck. What pose settings did you use for this image? Could it be a bug in Poser instead? I'm using the latest beta update for Poser on the Mac with 105 Mb of preferred memory assigned to it.
Al ( ) posted Mon, 27 March 2000 at 9:50 AM
I use Poser for Windows with latest patch. I have used Zygote Wall Sitting Pose enclosed with the model. Maybe it is a Poser bug but I have it only with Victoria. AL
chadly ( ) posted Mon, 27 March 2000 at 9:58 AM
I was told by Larry Weinberg that this is a problem that should have been fixed in the latest Poser patch. If you don't trust installing the patch the problem in quickly remedied by translating the innermatsphere for the twist rotation of the Upper Neck group ever so slightly in x (.0001 for example). Micah@Zygote
Al ( ) posted Mon, 27 March 2000 at 10:23 AM
UHM! I have used the latest patch on my system! The second test I have made was on a fresh installation of Poser 4 but without the patch. I'll try to install again Poser 4 again and patch again. The second solution seems to be a working one but I have tried the rendering without texture. I'll make you know the results a.s.a.p. AL
