Sun, Jan 12, 1:31 AM CST
Subject: editing paths? Mover Q.
Kurka ( ) posted Thu, 03 October 2002 at 6:53 PM ยท edited Tue, 24 December 2024 at 11:00 PM
Is there a way of editing waypoints once they have been defined by the Animation Wizard? Thanks, -Nando.
ArgentiumThri-ile ( ) posted Thu, 03 October 2002 at 9:54 PM
After you ended seting up your waypoints and close the wizard, you should see them, aren't you ??? Argentium Thri'ile
Kurka ( ) posted Thu, 03 October 2002 at 10:40 PM
Yes, but I'm unclear on how to move them. I don't seem to be able to select them individualy.
Alekssander ( ) posted Fri, 04 October 2002 at 1:05 AM
I never use the wizard but I belive you must have the animation editor up, then select each point in that, then move them around.
Kurka ( ) posted Fri, 04 October 2002 at 1:41 AM
I'll give it a shot. Thanks to all.- Nando.
gebe ( ) posted Fri, 04 October 2002 at 3:15 AM
Nando, Select the object you want to edit the path. Then, in the timeline select the keyframe you want to move (edit). In the four windows just move it wherever you want. In right-clicking in the timeline, you also can add a new keyframe or delete it.
Hope this helps.
Guitta
gebe ( ) posted Fri, 04 October 2002 at 3:29 AM
You also can select one of the red points directly in the windows. It becomes a white sqare. Then move it.
Kurka ( ) posted Fri, 04 October 2002 at 1:21 PM
Thanks,Guys!
